Aharon Dayan
Winter Dirt Because Winter Is Not Over Yet!!
Shalom and greetings all my pals,
Presenting a nice Boeing 777-200lr flight from CYEG Edmonton International Airport located 14 nautical miles south southwest of downtown Edmonton to KSEA Seattle–Tacoma International Airport located approximately 14 miles south of downtown Seattle
Airborne on climb to Fl360 after take off climbing through clouds
Now cruising at Fl360 across Canadian Rockies in Banff area
Dig those winter dirt details!
Cruising while admiring cockpit view of Canadian Rockies
All gauge readings look good!
Check out sun!!
Checking gauges again to be sure everything looks okay
Still cruising past Slocan lake
Some clever passenger using fancy camera with extremely powerful long range camera lense spotted this plane cruising below
Nice combo of engine view, river view of Upper Arrow lake, and sun
Approaching town or city of Kelowna visible below the nose of the plane
Same clever passenger used his fancy camera to capture this same plane climbing to Fl380 to avoid possibility of wake tuberlance caused by monster GE90 engines of my plane
Passing Kelowna and river of Okganagan lake
Same clever passenger using his camera captured the view of the same plane descending to Fl360 to fly in formation with my plane
Passing the same city or town where you can see bridge called William R. Bennett Bridge also known as highway route number 97 across the river in which its name is already mentioned above
Time to start descending!!
Same clever photographer used his camera to capture view of the same plane maneuvering to get ready for descent too
Still descending
Now at 10,000 ft above Summit Chief mountain
Clearing mountains which signals time to descent from 10,000 ft to 4,000 ft
Nice engine view of two famous stadiums lumen Field stadium and T-Mobile Park stadium with view of highway route 28 leading to two stadiums in front of engine and highway route 5 from left going right to engine intake
Engine view of bridge called lacey V Morrow Bridge also known as highway route 90 connecting between Seattle suburb called Judkins Park seen in front of engine and Mercer Island
Yeah the famous Seattle port
Passing the two same stadiums already mentioned previously
View of Harbor Island as part of famous Seattle ports
Descending to 3,000 ft to get ready for left 180 degree turn on way to runway 34l
Passing through clouds on way to runway
Seconds before touchdown
TOUCHDOWN
Front landing gear gliding slowly down in most graceful manner
Braking down
Taxing from runway 34l to gates via taxiway M
Still taxiing to gate
Thank you for viewing. Stay tuned for next exciting flight report.
Regards,
Aharon
קישור לתוכן
Share on other sites
