Aharon Dayan
Abort Procedure???
To all real life pilots, please take look at this video and I have question: why didnt the pilots immediately retract landing gear after aborted landing or is it required by procedures to leave landing gear deployed after aborted landing and take off??
קישור לתוכן
Share on other sites
You do retract them but it's not the number 1 priority. The aircraft will climb just fine with the gear down initially.
Going around is a very busy procedure. You need to set the power, pitch to the correct angle and make sure you are doing well. These are crucial.
Additionally, even after making the decisionand initial steps in a go around, you can still make ground contact. A good example is a strong wind shear and down draft.
After the initial steps have been taken and the rate of climb has been steadily positive, the gear is commanded up.
קישור לתוכן
