ha5mvo
Delco INS update
For those who use the Delco INS, a small update have been issue to adress the following:
What has been fixed
- Problem #0021 June 12, 2007
Bug in SDK InsAutopilotControlState() API
Turning unit 'x' (1<=x<=3) ON does not automatically turn other
active units OFF.
- Problem #0022 June 15, 2007
Fix in SDK external BatParallel state management.
- Problem #0023 June 10, 2007
The SDK diagnostic gauge distributed in the package is still the same
distributed with version 1.40 and, since the SDK is not compatible, it
does no longer work with gauges version 1.5x. Now supplied gauge has
been recompiled to be compatible with current SDK version.
- Problem #0024 August 30, 2007
Serious bug found in the Data Save and Restore functionality. When INS
State Data is saved, the gauge also saves the dynamically allocated list
of ADEU files. When such data is reloaded, ADEU gauge can cause FS to
crash. Now the list is deallocated before saving/restoring data to disk,
and then reallocated.
- Problem #0025 September 15, 2007
Wrong management of PI value and simulated drfting.
Inertial platform drifting should not occur until the aircraft is moved,
even if INS is already in NAV Mode.
What's new
- CDU Mouse Wheel support
Added mouse wheel support to:
- CDU Data selector knob
- CDU Dim control knob
- CDU Waypoint/DME selector
- ADEU filename selectors
Now they can be operated both with the left mouse button, as before,
and with the mouse wheel.
Available from the simufly website:
http://www.simufly.com/
