Izik Bakshi
עדכון לSERVER INFO
היום פורסם המייל הזה.
Hello all, We have finished compiling the "VATSIM-official" ServInfo data file update mentioned in the NOTAM sent back in September. The new data files and airline logos are available for download from the AVSIM file library at the web address found below. Before you install the update, you might want to make a backup of the FIR.dat and ServInfo.dat files in your ServInfo program folder, in case you have any problems after the update. Here is the web address for the file on AVSIM: http://library.avsim.net/download.php?DLID=115886 To install the update, simply unzip the file into the folder where you have ServInfo installed. Be sure your unzip program is set to retain file folders when unzipping. In WinZip, this option is called "Use folder names". Be sure that option is checked when you extract the zip file. When you extract the zip file, it will overwrite your FIR.dat and ServInfo.dat files, and you may be prompted to confirm that you wish to overwrite these files. Answer yes when prompted. You will also be prompted to overwrite the existing airline logo images. There are hundreds of these, so it's best to just say "Yes to all" when prompted to overwrite the files. If you have any questions, feel free to post in the VATSIM forums at the following location: http://forums.vatsim.net/viewforum.php?f=72 That's it! Our thanks go out to everyone that submitted data for this update, and a special thanks to Alex Stjepanovic for taking the time to collect all the data into a single set of data files. And of course a very special thanks to Michael Frantzeskakis for creating ServInfo in the first place. See you around the virtual skies!
LLBG עדיין בLLTA :?
ראיתי שהם שינו קצת את הגבולות במפה,והלוגואים השתנו.חוץ מזה לא ראיתי הבדל.
אפשר לשנות את זה באופן ידני עד כמה שאני זוכר. לא?
LLBG עדיין בLLTA :?
פתח את הקובץ Servinfo.dat, תגלה שיש שתי שורות עבור LLBG, אחת כ LLTA והשניה LLLL.
ניראה שזה הושאר שם בטעות.
שמתי ; לפני השורה עם ה LLTA ו LLBG נמצא תחת LLLL.
