Or Netzer פורסם אפריל 2, 2008 דיווח פורסם אפריל 2, 2008 here we see a prime example of what serving on a Merkava III does to somone.My genereation in the "Magach" would have found the answer himself. but no... our freind here has air conditioning in his tank... :mrgreen: :mrgreen: :mrgreen: ANYWAYS AES is a payware/ freeware addon that adds ground crew and ground services to the airports in FS. LLBG was recently added to the list of airports that the program is compatible with. הופה הופה לכלוכי שריון הא? :mrgreen: תודה על ההסבר .. היה קשה?:]
Ben Zwebner פורסם אפריל 2, 2008 דיווח פורסם אפריל 2, 2008 here we see a prime example of what serving on a Merkava III does to somone.My genereation in the "Magach" would have found the answer himself. but no... our freind here has air conditioning in his tank... :mrgreen: :mrgreen: :mrgreen: ANYWAYS AES is a payware/ freeware addon that adds ground crew and ground services to the airports in FS. LLBG was recently added to the list of airports that the program is compatible with. הופה הופה לכלוכי שריון הא? :mrgreen: תודה על ההסבר .. היה קשה?:] Not as hard as switching a "Mot Pitul" but you wouldnt know, youre limo of a tank doesnt have them HEHEHEHEHE :mrgreen:
Ido Rosenthal פורסם אפריל 2, 2008 דיווח פורסם אפריל 2, 2008 here we see a prime example of what serving on a Merkava III does to somone.My genereation in the "Magach" would have found the answer himself. but no... our freind here has air conditioning in his tank... :mrgreen: :mrgreen: :mrgreen: ANYWAYS AES is a payware/ freeware addon that adds ground crew and ground services to the airports in FS. LLBG was recently added to the list of airports that the program is compatible with. הופה הופה לכלוכי שריון הא? :mrgreen: תודה על ההסבר .. היה קשה?:] Not as hard as switching a "Mot Pitul" but you wouldnt know, youre limo of a tank doesnt have them HEHEHEHEHE :mrgreen: עכשיו חזרתי הביתה ממילואים, שבוע בשטח וטפ"ש וזו ההודעה הראשונה בפורום? הלכתי לישון...
Or Netzer פורסם אפריל 2, 2008 דיווח פורסם אפריל 2, 2008 here we see a prime example of what serving on a Merkava III does to somone.My genereation in the "Magach" would have found the answer himself. but no... our freind here has air conditioning in his tank... :mrgreen: :mrgreen: :mrgreen: ANYWAYS AES is a payware/ freeware addon that adds ground crew and ground services to the airports in FS. LLBG was recently added to the list of airports that the program is compatible with. הופה הופה לכלוכי שריון הא? :mrgreen: תודה על ההסבר .. היה קשה?:] Not as hard as switching a "Mot Pitul" but you wouldnt know, youre limo of a tank doesnt have them HEHEHEHEHE :mrgreen: עכשיו חזרתי הביתה ממילואים, שבוע בשטח וטפ"ש וזו ההודעה הראשונה בפורום? הלכתי לישון... מוט פיטול? מזה ? יש לנו מספיק דברים קשים אני מבקש... אתה יודע איזה רעש המזגן והמנוע עושים ביחד??? נו באמת.. חראם על עור התוף :mrgreen: מילואים על הסובארו? (מרכבה 2?) עידו איך הידיים.. חום סגול כהה? שומניות עם ריח סולר? :mrgreen: פריסת זחל עשיתם? :mrgreen:
Ido Rosenthal פורסם אפריל 3, 2008 דיווח פורסם אפריל 3, 2008 מרכבה 2? חס וקרפס! אנחנו מג"חניקים חביבי.... האמת שלא היו שום תקלות רציניות, בעיקר תקלות קשר ופה ושם תקלות בק"ש, אם היו מגייסים גם חימוש לאימון אז לא היינו מרגישים את זה. סובארו סובארו אבל תותחנים שלא נגעו בטנק 5 שנים הביאו פגז ראשון מטרה מתחת ל10 שניות, סה"כ החזיר לנו את הביטחון בקופסאת פח שלנו...
AaronDagan פורסם אפריל 3, 2008 דיווח פורסם אפריל 3, 2008 מרכבה 2? חס וקרפס! אנחנו מג"חניקים חביבי.... האמת שלא היו שום תקלות רציניות, בעיקר תקלות קשר ופה ושם תקלות בק"ש, אם היו מגייסים גם חימוש לאימון אז לא היינו מרגישים את זה. סובארו סובארו אבל תותחנים שלא נגעו בטנק 5 שנים הביאו פגז ראשון מטרה מתחת ל10 שניות, סה"כ החזיר לנו את הביטחון בקופסאת פח שלנו... הלו, חברים, קצת נסחפתם, לא?
Or Netzer פורסם אפריל 3, 2008 דיווח פורסם אפריל 3, 2008 מרכבה 2? חס וקרפס! אנחנו מג"חניקים חביבי.... האמת שלא היו שום תקלות רציניות, בעיקר תקלות קשר ופה ושם תקלות בק"ש, אם היו מגייסים גם חימוש לאימון אז לא היינו מרגישים את זה. סובארו סובארו אבל תותחנים שלא נגעו בטנק 5 שנים הביאו פגז ראשון מטרה מתחת ל10 שניות, סה"כ החזיר לנו את הביטחון בקופסאת פח שלנו... הלו, חברים, קצת נסחפתם, לא? שריון לא נסחפים לעולם, רק קצת הכוונת אבל בשביל זה יש אפס"ח. פשש ראשון בפחות מ10? אני הפגז הראשון בחיים שלי עשיתי ב8 :mrgreen: ושני אחריו ב14 אבל זה כי היה מלאא פודרה מסביב וגם המפקד לא יכול היה לכוון אותי למטרה. תקלות קשר זה מצחיק, איך הנהג לא שומע בקש"פ ואז עד שהוא נזכר לשמוע והמפקד כבר צורח עליו בעצבים הוא דופק ברקס כזה עצבני שמפוצץ לטען למפקד ולי את המצח. איך מגייסים אימון בלי חוליה? התגברתם על תקלת בק"ש? והסובארו זה מרכבה 2, למג"ח יש לי כבוד.
