ha5mvo פורסם יוני 3, 2008 דיווח פורסם יוני 3, 2008 Has been out for a little while now, since it wasn't mentioned - I'll pick the glove on this one. This one is clearly an upper echelon addon for FS, perfectly suited for those (like myself) who don't have the time or the will to sit for hours locked at cruise phase on a transatlantic. It's range and typical flights take up 1-1.5 hour sessions. No, you're unlikely to see it in LLBG or slap an ElAL skin on it - I guess some find this important though it obviously limits them to a Boering 7[fill blank here]7 Like most modern jets it's highly automated, which makes it relatively easy to operate. Pre- flight procedures are relatively shot for that reason. The system modelling is quite comprehensive and there's very little that's left out. Among others, the system include, a fully functional WXR, terrain display as well as an IRS, TCAS, an (almost) fully functional FMS etc. It also has a multicrew feature and some nice touches including a virtual FO and an immersive soundset. A well polished product overall. The most impressive attribute on this model, has actually very little to do with the systems. Namely it's the frames. I have never seen an addon of parallel complexity that performs so well. Even with all features on, it runs only a few frames behind the default lear or 737 still providing a very smooth display. On the downside - it has no VC at this point. The developer promises it would be available in the future but knowing how things work in addon development, if you find the VC to be a must - I suggest you wait. Personally I couldn't care less about VCs (as a matter of fact I always remove them) but I know they are very much in fashion nowadays. There are also some small glitches that are to be addressed in a service pack. Nothing too major though.
bar levy פורסם יוני 3, 2008 דיווח פורסם יוני 3, 2008 יש לי את המטוס הזה מטוס מדהים! באמת החוסר בVC לא מפריע ואני נהנה מכל רגע בו. מי שצריך עזרה שישאל
אורח פורסם יוני 4, 2008 דיווח פורסם יוני 4, 2008 נשמע מצויין, רק יכול להיות שזו שעת הבוקר המוקדמת, מי החברה איפה הלינק ותודה על הסקירה .
ha5mvo פורסם יוני 4, 2008 מחבר דיווח פורסם יוני 4, 2008 נשמע מצויין, רק יכול להיות שזו שעת הבוקר המוקדמת,מי החברה איפה הלינק ותודה על הסקירה . The Developers publish it through "Digital Aviation" their website won't contain too much, but there's a screenshot section on their forum so you might get a better impression: http://digital-aviation.de/forum/viewfo ... 8f716acd82 there are a couple of clips and some feature examples in the stickies, so you can get an impression on how it looks like. feature list is here: http://www.digital-aviation.de/forum/vi ... =46&t=3172 and the purchase is through Flight one, for 50 bucks US - not outrageous at all.
אורח פורסם יוני 4, 2008 דיווח פורסם יוני 4, 2008 נשמע מצויין, רק יכול להיות שזו שעת הבוקר המוקדמת,מי החברה איפה הלינק ותודה על הסקירה . The Developers publish it through "Digital Aviation" their website won't contain too much, but there's a screenshot section on their forum so you might get a better impression: http://digital-aviation.de/forum/viewfo ... 8f716acd82 there are a couple of clips and some feature examples in the stickies, so you can get an impression on how it looks like. feature list is here: http://www.digital-aviation.de/forum/vi ... =46&t=3172 and the purchase is through Flight one, for 50 bucks US - not outrageous at all. שיכנעת אותי בקרוב סוס חדש באורווה שלי, ננסה לשכנע את AIT BIS לרכוש כזה
