Etai Charit
עריכת Aircraft.cfg - קובץ שימושי
שלום,
מצאתי ברשת מסמך (קרדיט בפנים) שיכול מאוד לעזור בעריכת קובץ CFG של כל מטוס.
תהנו.
 Comments on aircraft.cfg    12/23/02; 10/10/03; 01/22/05; 08/28/05
ron.freimuth@att.net
  This shows what is important for many of the aircraft.cfg lines and
  which have no effect unless FSEdit is used to FUBAR the AIR file.
  One can save a backup of the air file, then copy it back over any
  FSEdit messed up air file if FSEdit is used to edit aircraft.cfg.
[WEIGHT_AND_BALANCE]      << Values here are for C172N
max_gross_weight= 2300    << For reference and FS9 Fuel menu only
empty_weight    = 1490    << Weight with no payload or fuel
reference_datum_position = 3.66, 0.00, 0.00   << Offset from FS Reference
 Normally at Wing Chord/4, Centerline, Vertical offset
 Zoom in on side spot view to find location in .mdl and set wing location
 tanks, loads, etc. as appropriate.  This may also involve up/down offsets
 Note: the FS Reference is at the Center of Lift
empty_weight_CG_position =-3.50, 0.00, 0.00 << Sets CG when empty
 Usually set negative so empty CG is at FS Reference, which is
 typically at 25% of Wing Mean Aerodyanic Chord
max_number_of_stations=20 << Set to 20 unless more are needed
;           no    wght, long, lat, vert
station_load.0  = 190, -3.2, -1.1, 0.0    //Pilot
station_load.1  = 150, -3.2,  1.1, 0.0    //Co-Pilot
station_load.2  = 97 , -6.1,  1.1, 0.0    //Rear Passenger
station_load.3  = 49 , -6.1, -1.1, 0.0    //Rear Passenger
station_load.4  = 0.0, -8.0,  0.0, 0.0    //Baggage
; 1490 empty                  << My comments and calculations
; 486 passengers and baggage
; 324 fuel 54 gal * 6.0
; 2300 lb
//Moments of Inertia
empty_weight_roll_MOI   = 948     // In slug-ft2
empty_weight_pitch_MOI  = 1346
empty_weight_yaw_MOI    = 1967
empty_weight_coupled_MOI= 0   << Usually 0, can reduce Yaw-Roll Stability
CG_forward_limit= 0.150   << Not currently used. AFSD displays as "%"
CG_aft_limit=     0.350   <<  " "
 There are various sources that give the Moments of Intertia for many AC.
 Note Yaw MoI is near Pitch + Roll.
 Given the same AC form, they vary as AC_Length^5. Or, with Weight^2.
 The offsets below are based on Reference Datum offset = 0, 0, 0.
 Otherwise, the distances along the fuselage change.
 Entries marked "No Effect" are used by FSEdit to set
 new parmeters in the AIR file. Some of these are inappropriate.
 "No Effect" entries may affect FFB JS's, so it is desirable to set
 tail areas and distances at least approximately.
[airplane_geometry]
wing_area=1700.0      << Most important
wing_span=108.0       << Also Important
wing_root_chord=15.7  << No Effect, FS calculates MAC. Probably as MAC=area/span. AR=b^2/S; MAC=b/AR
wing_dihedral=3.0     << Probably affects MAC Vertical Offset. This can be set from front view.
wing_incidence=0.70   << This, and twist, affect cruise pitch
wing_twist=-3.0       << However, they have No Effect in FS9. TBL 404 must be adjusted.
 There is a parameter in the AIR file that should
 be changed when either of the above are changed:
 REC 1101 "Fuselage AoA at Min Induced Drag"
 Changing 'cruise_lift_scalar' (below) to adjust cruise pitch also
 requires change in REC 1101. Otherwise Induced Drag will be off
oswald_efficiency_factor=0.   << Affects Induced Drag
 Typically 0.70 low wing,  0. high wing, 0.78 for jet transports
wing_winglets_flag=0        << 1=T Reduces Induced Drag
  Appears to improve oswald_efficiency by 7%, often too much
  May be better to not use, and set oswald_efficiency slightly higher
wing_sweep=0.0              << wing_pos_apex_lon has to be moved forward
 of the LE of the MAC if this is set
wing_pos_apex_lon=3.93      << Set to MAC/4  15.7/4 = 3.93
 This appears to only set the %CG reading offset, not the
 Center of Lift (normally 25% of MAC aft the LE)
 The Center of Lift is at the FS_Reference !
wing_pos_apex_vert=0.0      << may be + 2.0 for high wing
htail_area=376.0            << No Effect
htail_span=35.75            << No Effect
htail_pos_lon=-65.9         << No Effect
htail_pos_vert=19.29        << No Effect
htail_incidence=2.0     << 0.0 to 3.0 may improve pitch stability
 Set Sign for DOWN force on tail. H. Stab CL ~-0.02 (~5% of CL wing in cruise [AFSD displays this])
htail_sweep=0.0         << No Effect
vtail_area=356.0        << No Effect
vtail_span=21.5         << No Effect
vtail_sweep=0.0         << No Effect
vtail_pos_lon=-46.2     << No Effect
vtail_pos_vert=15.1     << No Effect
elevator_area=108.0     << No Effect
aileron_area=67.4       << No Effect
rudder_area=66.2        << No Effect
elevator_up_limit=27.0  << Can be found in FAA TCDS data
elevator_down_limit=17.0 << FAA TCDS data
aileron_up_limit=17.0   << FAA TCDS data
aileron_down_limit=17.0 << FAA TCDS data
rudder_limit=25.0       << FAA TCDS data
elevator_trim_limit=13.0 << FAA TCDS data (set to H. Stab limit for jets)
spoiler_limit=60.0      << FAA TCDS data
spoilerons_available=1  << 1=T, 0=F
aileron_to_spoileron_gain=2.6   << Ratio of spoileron to aileron deflection
min_ailerons_for_spoilerons=8.5 << Degrees. Might be 0
min_flaps_for_spoilerons=0.0    << Flaps deflection required for spoilerons
 Spoilerons increase Roll Rate when moved. Amount set in AIR file.
[Reference Speeds]
flaps_up_stall_speed=165    << Probably no effect but set if missing on AC load
full_flaps_stall_speed=132  << Probably no effect  "   "
cruise_speed=434.8          << Used for AI  and Nav Log
 I think this should be in IAS cruise speed if used as an AI aircraft
 so it doesn't fly too fast. About 260 kts for jets. However, it should
 be set to TAS cruise speed for the FS Nav Log time predictions
[flaps.0]
type=1              // 1 - tail, 2 - lead << No Effect
span-outboard=0.41  // 0.0 .. 1.0         << No Effect
extending-time=8    // seconds
system_type = 0                           << 0=elec, 1=hydraulic, ..
lift_scalar=1.00                          << Adjusts AIR file value
drag_scalar=1.00                          << Adjusts AIR file value
pitch_scalar=1.00                         << Adjusts AIR file value
flaps-position.0=0                        << degrees
flaps-position.1=15
flaps-position.2=35
damaging-speed=140                        << Optional
blowout-speed=180                         << Optional
[flight_tuning]
cruise_lift_scalar = 1.0    << SDK: "use to adjust cruise pitch"
 This also affects location of Induced Drag parabola.  See "wing_twist" above.
parasite_drag_scalar = 1.0  << Adjusts "Drag - Zero Lift"
 Often too high in jet AIR files, 0.8 might be appropriate for such files
 Set for appropriate TAS or PPH but see "TurbineEngine"
induced_drag_scalar   = 1.0 << 1.0 should be good if 'oswald_efficiency_factor' appropriate
elevator_effectiveness= 1.0 << These three might be set as required
aileron_effectiveness = 1.0
rudder_effectiveness  = 1.0
pitch_stability = 1.0   << Increase if ALT hold 'hunts'
roll_stability  = 1.0   << Damps Roll, reduces roll rate
yaw_stability   = 1.0   << Increase if AC is unstable in Yaw
   Dampings are often too high in AIR files
   Set < 1.0 to improve (this also requires reduction in
   elevator_effectiveness, etc, above
elevator_trim_effectiveness= 1.0 << Enough so AC almost stalls at full UP trim
aileron_trim_effectiveness = 1.0 << Lower gives finer control - often desirable
rudder_trim_effectiveness  = 1.0 <<  " "
[TurbineEngineData]
fuel_flow_gain=0.004  << Affects spool up rate by changing fuel controller gain
inlet_area=9.       << Set near or 10% above real turbine inlet area to
 start.  Higher values increase ram drag, less net thrust at high speeds
rated_N2_rpm = 12250  << can be left at 29920
static_thrust= 17000  << Set to get rated thrust at rated SL N1
 This may be lower or higher than actual TO rating,
 full throttle usually sets higher than rated TO thrust
afterburner_available=0
reverser_available = 1 << Reverse thrust.  Value set in AIR file
 Insufficient Reverse thrust can be fixed by increasing 'Reverse Thrust
 Throttle percent' to about -50 in AIR file (or to -0.50 in FS9 aircraft.cfg).
[GeneralEngineData]
engine_type= 1
Engine.0=-49.7,-9.3, 2.00 //moved up so thrust vector pitches nose down
Engine.1=-65.1, 0.0, 3.00
Engine.2=-49.7, 9.3, 2.00
 These locations are for the "center of thrust", not the engine!
 At prop location or about 2/3 of the way back along a turbine
 Up/Down from Vertical CG/CoL will add a pitching moment with power changes
fuel_flow_scalar=1.60   << Sets SFC=0. for 1970's turbine
 This should always be above 1.0 for turbines. SFC=fuel_flow_scalar/2
 Typical Specific Fuel Consumption cruise values range from 0.55 to 0.90
 So, fuel_flow_scalar would be 1.1 to 1.8.  Maybe 2.5 for old Military jet
 Then, set Cdo or parasite_drag_scalar to get appropriate fuel flow in
 flight. If drag is appropriate to start, then fuel_flow_scalar can be
 adjusted to get correct fuel flow in cruise.
       ----------- Prop AC --------------
[GeneralEngineData]
engine_type     = 0     << reciprocating
Engine.0        = 2.34, -0.40, 0.00   << Prop location!
 Prop is offset to the left here to compensate for prop effects
fuel_flow_scalar= 1.00  << Adjusts fuel flow vs HP
 1.00 is good for reciprocating engines (SFC=0.46 at best power mixture)
[smokeSystem]
//smoke.0         = -2.0,-0.0 ,2.0, fx_smoke_rx
[piston_engine]
cylinder_displacement=.0  << Total displacement/number of cylinders
compression_ratio=9.0       << Small effect on HP, lower reduces it
number_of_cylinders=4       << Power is proportional to number of cylinders
max_rated_rpm=2750          << Sets RPM for governed prop
max_rated_hp=160            << Changes engine sound level and CHT, etc. NOT HP!
fuel_metering_type=1        << 0 for fuel injected (which maintains power inverted)
cooling_type=0              << 1 for water
normalized_starter_torque=0.1 << Lower slows engine start up
turbocharged=0
max_design_mp=0.0             << Typically 35.0 for turbocharged engine
min_design_mp=0.0             << 5.0 might be appropriate
critical_altitude=0.0         << Maximum altitude turbocharger holds full MP
 Best set to altitude maximum rated MP, not max SL MP is maintained
emergency_boost_type=0
emergency_boost_mp_offset=0.0   << Can't use in FS2K2, for CFS3?
emergency_boost_gain_offset=0.0 <<  " "
fuel_air_auto_mixture=0         << 1 locks out mixture control
auto_ignition=0
fuel_flow_scalar=1.0            << Only works in [GeneralEngineData]
max_rpm_mechanical_efficiency_scalar=1.0  <idle_rpm_mechanical_efficiency_scalar=1.0 <  These two adjust the end points of TBL 508 in the AIR file
 "max_rpm_..._scalar" can be used to ADJUST SHP at SL (59F, 29.92")
max_rpm_friction_scalar=1.0     << Affects HP at high RPM, increasing reduces ceiling
idle_rpm_friction_scalar=1.0    << Affects idle RPM
 These two adjust the end points of TBL 509 in the AIR file
 Increase in max_rpm_friction may require increase in 'max_rpm_efficiency' above
power_scalar=1.0                << Adjusts HP from norm, probably scales TBL 508, internal torque vs RPM
[propeller]
propeller_type=1          << 1 = Fixed Pitch, 2 = Variable Pitch
propeller_diameter=6.25   << Critical, small increase loads engine more
propeller_blades=2        << No Effect
propeller_moi=2.0         << Affects Prop gyro effects and RPM change rate
 ~(0.6/386)*Weight_Prop*Dp^2; Or, try 2.0*(Dp/6.25)^5 (based on C172 prop)
beta_max=35.0    << For Variable Pitch props
beta_min=15.0    <<  "  "
 Prop tbls in AIR file limit usable beta_max and beta_min
min_gov_rpm=1400.0    << For Governed Props, 1600 is probably better
prop_tc=0.010         << RECIPROCAL of Prop Governor Time Constant
 Lower smooths RPM changes,  0.002 may be appropriate
gear_reduction_ratio=1.0    << Above 1.0 if prop RPM < engine RPM
fixed_pitch_beta=20.0       << Sets fixed pitch blade angle.
low_speed_theory_limit=.0 << Lower may reduce TO distance - but .0 is good
prop_sync_available=0       << Twins
prop_deice_available=0      << This works if set to '1'
prop_feathering_available=0 << Usually '1' for Twins
prop_auto_feathering_available=0  <<  "  "
min_rpm_for_feather=0       << Often 700.0 (RPM)
beta_feather=0.0            << Feathered blade angle, ~82.0 deg
power_absorbed_cf=0.0       << Prop Cp at Feathered Beta
  May affect Idle RPM if beta_feather=0
defeathering_accumulators_available=0
prop_reverse_available=0
minimum_on_ground_beta=0.0  << Set to beta_min if no turboprop 'Beta' control is needed
minimum_reverse_beta=0.0    << ~-12 deg if used
thrust_scalar=1.0           << Leave at 1.0
rotation=1,1,-1,-1     << This would set CW rotation for engs #1 & #2, CCW for #3 & #4
 Only needed if CCW rotating engines are desired. '0' sets zero rotation
[electrical]
;BusTypes:0=MainBus, 1=AvionicsBus,
;2=BatteryBus, 3=HotBatteryBus,
;4-7=Generator/AlternatorBus(1-4)
max_battery_voltage=25.2            << 1/2 this for 12 V system
generator_alternator_voltage=28.5   <<  " "
max_generator_alternator_amps=50.0  << Probably sets load limit
;       BusType, MaxAmpLoad, MinVoltage
flap_motor         = 0, 10, 18.0    << 1/2 these values for 12 V system
gear_motor         = 0, 15, 17.0
autopilot          = 0, 5 , 21.0
avionics_bus       = 0, 10, 17.0
avionics           = 1, 5 , 22.0
pitot_heat         = 0, 2 , 17.0
additional_system  = 0, 1 , 16.0    << Clock and Elec Turn Indicator
marker_beacon      = 1, 1 , 17.0
gear_warning       = 0, 1 , 17.0
fuel_pump          = 0, 2 , 17.0
starter1           = 0,200, 16.0
light_nav          = 0, 3 , 17.0
light_beacon       = 0, 3 , 17.0
light_landing      = 0, 3 , 17.0
light_taxi         = 0, 3 , 17.0
light_strobe       = 0, 1 , 17.0
light_panel        = 0, 1 , 17.0
 Reduced currents extend battery life, especially if lights, etc. are
 turned off and 'additional_system' is set to 1 A.  One can also make
 loads die at different voltages.
[autopilot]   //some for FS9 only
autopilot_available       = 1
flight_director_available = 1
default_vertical_speed    = 1000
autothrottle_available    = 1  //0  << Works to hold IAS/Mach in all AC
autoland_available        = 1  //0  << May cut engine after ILS landing
pitch_takeoff_ga          = 10.0 //9.0 Set so AC climbs well with Shft-Ctl-G TO
autothrottle_arming_required=0
autothrottle_takeoff_ga   = 0   << RPM locked for TO
autothrottle_max_rpm      = 105 << Holds N2 or Prop RPM, set >100 for CS props
use_no_default_pitch      = 1  // 0 = Default to current pitch mode, 1 = No default
use_no_default_bank       = 1  // 0 = Default to Wing Leveler mode, 1 = No default
default_pitch_mode=0
default_bank_mode=0
max_pitch=10.0           // no effect except on GS lock
max_pitch_acceleration  = 3.0  //1.000
max_pitch_velocity_lo_alt=3.0  //2.000
max_pitch_velocity_hi_alt=1.500
max_pitch_velocity_lo_alt_breakpoint=20000.0
max_pitch_velocity_hi_alt_breakpoint=28000.0
max_bank=25.00
max_bank_acceleration=1.
max_bank_velocity=3.00
max_throttle_rate=3.50            // set lower if rpm surges
nav_proportional_control  = 15.0  //default '9.00'
nav_integrator_control    = 0.15  //0.250
nav_derivative_control    = 15.0  //Should affect damping, 15 may be too high //0.00
nav_integrator_boundary   = 2.50
nav_derivative_boundary   = 0.00  //Might help if 45 deg and nav_deivative set
gs_proportional_control   = 26.0  //9.52  Higher helps hold GS
gs_integrator_control     = 0.260
gs_derivative_control     = 10.0  //Should affect damping, 10 may be too high //0.000
gs_integrator_boundary    = 0.70  //1.5 deg may help
gs_derivative_boundary    = 0.00  //10 deg might improve GS if gs_derivative set
yaw_damper_gain           = 2.0   //0.0 disables YD, little difference above 1.0
 ------- FS9 Addition(s) -------------------
// ADD to aircraft.cfg so IAS reads same as in FS2K2 !
[airspeed_indicators]  //IAS adjustment parameters
airspeed_indicator.0 = 0.9826, 0.0   //Appropriate values for Jet AC
      These values will change '255 kts' IAS at Mach 0.745, FL 350
      to '250 kts'.  Which is essentially CAS
airspeed_indicator.0 = 1.111, -10.0   //Appropriate for C182, C208, etc.
     IAS displays 100 kts at CAS = 100 kts
      The "1.111" is equivalent to the "Weighting Factor" scaled integer
      In REC 1101 of the AIR file.  The "-10.0" is the IAS "Base Offset"
