Chris Bell
Night lights
TY Joel
these are fixed poly's from custom asm code
its going to brutal to get these all over
im trying to script this somehow; not sure yet how to go about it
but i am happy  somewhat with the general effect now
still need to tweak the asm code
Hi Chris,
What's your method of generating the night textures? There are several ways to go about it e.g:
1. make black layer over your photo, set opacity to about 25%
2. pick dark orange colour (best way is to pick this colour from the original FSX night texture), set brush hardness to 0, brush size compatible with your streets on the photo
3. paint along the streets and around the buildings (you don't have to be precise because it will be scattered light)
4. set opacity to 100%
5. Layer -> Layer style -> Blending options -> MULTIPLY (in GENERAL BLENDING)
6. Image -> Adjustments -> Selective Color Choose RED and play with MAGNTEA bar to achieve the best result.
TY Mike
in my first attempt; i adopted a C# script targeting gray areas in the image; then dialed in the colors o be replaced
ive used transparency to the source image below
i wasn't very impressed with my final results; felt cheep
although i run the whole country already
i ditched the coloring technique
the last attempt is custom asm code
just a heads up
i hope many of you are reading this
to get my latest lights effect to cover Israel
i will need the community's help to bring this to fruition
with the latest attempt; each light ball is hand placed
!i cannot hand place all the country by myself
but if we all come together in small groups
each covers a small segment
we can have this completed in matter of just few weeks
ill need the poly lines placed on google earth map
then exported to a kml file; which i will convert to usable data to place the lights
the lines don't need to be in ay order and can crisscross each other
we just need the dots placed in the right place on the map
as each dot becomes an active light
(like such (see image
!the cards are on the table vatil community, its your turn
