Chris Bell
FPS Increase with DxtFixerX v2.1
little tool with big impact - searches for dxt3 and dxt5 textures with bad alpha channel data, and repairs them
DxtFixerX v2.1
by Peter Nyman
http://library.avsim.net/esearch.php?DLID=178342
authors active threads
http://forum.avsim.net/topic/382519-a-huge-fps-increase/
or
http://forum.avsim.net/topic/382755-dxtfixerx
this doesn't alter or affects  graphics or your settings
this actually helps your global FPS
by correcting textures with curtain known issues
which causes shutters and other visual artifact
users who used this tool are reporting huge FPS increase
especially with heavy's
the first link is an active discussion for the tool
it found some files:
DxtFixerX for FS9 and FSX - by neumanix 2012
THE FOLLOWING FILES ARE BAD:
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\Ercoupe_001a.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\Ercoupe_001a_LM.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\Ercoupe_001b.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\Ercoupe_001b_LM.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\PA28_001.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\PA28_001_LM.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\PA28_002.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\PA28_002_LM.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\PA28_003.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Addon Scenery\LHC_Alaska\texture\PA28_003_LM.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\aerosoft\29Palms - Skiathos X\texture\JSI_Dummy.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\aerosoft\FSDG - Kastellorizo X\Texture\LGKJ_Buildings_1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\aerosoft\FSDG - Kastellorizo X\Texture\LGKJ_Chapels.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\aerosoft\FSDG - Kastellorizo X\Texture\LGKJ_Flags.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\aerosoft\FSDG - Kastellorizo X\Texture\LGKJ_Graveyard.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\aerosoft\Norilsk X\Seasons\fall-spring\texture\sf2.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\flare39.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\flytampa_halo1_LOD.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\fx_Alabeo.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\fx_shtstar.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_flash_left_appr.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_flash_left_apprflare.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_flash_left_flare.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_flash_right_appr.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_flash_right_apprflare.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_flash_right_flare.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\mjc_prop_positionadjust.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Effects\texture\rospot1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\Global\Texture\Area1Specular.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\Global\Texture\Area3Specular.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\Global\Texture\Area5Specular.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\props\texture\prop_turbine1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\props\texture\prop_turbine2.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\123b2su1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\124b2fa1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\124b2hw1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\124b2sp1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\124b2su1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\124b2wi1.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\Road2LandAsphaltSU-256.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\roadslm.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Scenery\World\Texture\roadssu.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\WoA_AIA_B738_W\texture.CAL-China Airlines Lavender\aia_737_800_l.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\WoA_AIA_B738_W\texture.CRK-Hong Kong Airlines\aia_737_800_t.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\WoA_AIA_B739_ER\texture.KLM-KLM Royal Dutch Airlines\AIA_737_900_l.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\WoA_AIA_B744_GE\texture.CAL-China Airlines Dreamliner\aia_747_400_ge_l.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\WoA_AIA_B744_PW\texture.SIA-Singapore Airlines\aia_747_400_pw_t.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\Airplanes\WoA_DJC_A319_IAE\texture.CCA-Air China_lsf Air Macao\DJC_A319_iae_t.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\SimObjects\GroundVehicles\FuelTruck\texture\fueltruck.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0000.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0001.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0002.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0003.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0004.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0005.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0006.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0007.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0008.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0009.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0010.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0011.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0012.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0013.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0014.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainMoving0015.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0000.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0001.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0002.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0003.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0004.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0005.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0006.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0007.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0008.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0009.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0010.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0011.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0012.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0013.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0014.bmp
C:\Program Files (x86)\Microsoft Games\Microsoft Flight Simulator X\Texture\VCRainStopped0015.bmp
looks like it won't backup the files before it does changes so I quickly back-uped these files. Applying the tool now.
