lalex
FSX Hardware Upgrade guide
Alex, with all due respect to hardware guids, I believe the best advice at the moment is just to sit and wait.
with DX10 around the corner one would probably like to get a card that supports it. The snag is, that there is a fair likelihood of the first generation cards turning out crap. Add to this the time it takes for prices to drop a little and that waiting period might drag even longer
This is my biggest issue with fsx - it should run decently out of the box!
having to spend litteraly THOUSENDS of dollars, just to get an acceptable performance is simply outrageous, especially if you condiser the official "minimal requirements"
I , for one, am not willing to pay so much for high-res textures - lovely as they might be.
but then again, to each his own......
Michael,
This guide comes to explain which HW part has influence on which FSX feature - nothing more.
The document does not say WHEN to buy anything so with all due respect, your observation is not relevant to the content od the document.
Al
True, it does not.
Tough I am assuming that the target audience of an upgrade guide are the ones who intend to do so in the near future and not a year or 18 months from now - hence my additional remarks
Alex, and all others who follow this thread.
This is the best piece of information I read so far as for what is needed, in terms of hardware, for running FS-X at a reasonable performance. It is clear, strait forward and explains, in simple terms, what each component does for running your FS-X.
I was among the lucky ones who got the last beta version from MS (for testing the compatibility of Israel’s FS-2004 sceneries with the new simulator) and therefore I was able to see how FS-X runs on my recently bought PC
Here are the specs of the machine. As you can see they are, more or less, matching the recommendations of Excitingsimulation PDF document. Please note that I am running 3 monitors on one PC;
Motherboard - ASUS A8N32-SLI DELUXE - (nForce4 SLI) - ATX
CPU - AMD Athlon 64 (3700+) San Diego - (939 Pin)
Two Memories - 1GB Samsung DDR PC3200/400 each. Total 2 GB
Two PCI-Express video cards – ASUS - EN7900GT 256MB 2DHT DDR - PCX
HDD - WD 200GB-8MB JD - 7200RPM S-ATA II
HDD - WD 80GB-8MB JD - 7200RPM S-ATA II
Case - Thermaltake Middle Tower – aluminum Armor-Jr Middle Tower - Silver, with 680 W power supply.
For more information please go to;
http://www.sk-flightsim.com/pc_hardware.html
the results are as good as running FS-2004
And another thing, good people who contribute to our community, are already working on tweaks that will make things better. For example, I saw yesterday on Avsim a new upload that replaces the 1024 textures with 512 ones
It is the same story as FS-2002\FS-2004. I still remember people say it will take 2 years for the new sim to replace the old one. In reality it took 3-4 months
Thanks Seev for the kind words. I am happy that you found it useful.
You have a dream machine and I am not surprised that it "runs as well as FS2004". I imagine that you forgot to say that it is also 100 times more beautiful and sophisticated than FS2004 too, especialy with those killer graphic cards!
Have lots of fun with the new "monster"
True, it does not.
Not really. The target audience is everyone who considers doing any kind of upgrade for running FSX better regardless of "when". The information is updated for the foreseeable future of course, but I plan to maintain the document to be up to date with the latest technology - and that means that I will probably do so once every 6 months - unless I find a critical mistake in teh table, etc.
BTW, the link is not valid anymore for reasons that will be obvious later on. An updated link will be posted in the near future.
המדריך הזה היה יותר מדי טוב כדי "לפספס" אותו, אז בברכתו של אלכס המדריך צורף לPRC 8)
המידע והלינק למדריך (המעודכן) כאן - http://forums.vatsim.net/viewtopic.php?t=14009
המון תודה אלכס!
אילן
נ.ב. - המדריך נותן מידע רלוונטי גם לFS2004. למעשה, הוא נותן מידע שבדיוק חיפשתי עכשיו כדי לשפר את הFPS שלי :lol:
המון תודה אלכס!
אילן
Thanks Ilan,
Have fun with your new computer!
:D
גם אני מצרף את תודתי לאלכס - מסמך מאיר עיניים :!:
תודה רבה על ההשקעה וההסברים :P
ובעניין הזה שהעלית אילן - בדיוק סיימתי לקרוא את המסמך עד סופו ואני תוהה כמה ממנו רלוונטי גם לגבי ה-FS9 :?: :?: :?:
אני עדיין לא חושב על FSX (על כל הכרוך בכך) בעיקר בגלל שאני (עדיין :cry: ) בעיצומה של המלחמה על הפריימים ב-FS9.
אשמח ואודה להתייחסויות ומידע לגבי הנושא הזה.
תודה.
תודה.
דן שגר לי את המפרט של המחשב שלך.
לא יתכן שמחשב שהוא יחסית חדש צריך להלחם על פריימים....
לא קראתי את כל המסמך כי הוא כבד....ומעייף, אבל אני אשאל אתכם כאן:
קניתי לא מזמן מחשב חדש והמפרט הוא כדלקמן:
intel core 2 due e6400
לוח אם: asus p5w dh-deluxe
leadtek px7900gt 256mb sli tdh
2gb corsair 667 mhz
ה-FSX שלי די מקרטע על הגדרות מקסימליות, ואני לא רוצה לדמיין מה יהיה עם תוספים וכו'...
מה לעשות?
רבותי, עם כל הכבוד דברו עברית, אני מבין אנגלית דיי טוב אבל להתחיל לקרוא מאמרים של 50 עמודים זה ארוך ולא מתאים למסגרות הזמן....יש למישהו עצה???
ובאמת חבר'ה, עברית שפה יפה, כיתבו בעברית כאן.
רז.
רז.
רז - כמה שאלות ברשותך. תגיד:
אתה מטיס מטוסים שמגיעים עם מדריכים מקוצרים (10 דפים מקסימום) ובעברית בלבד :?: :?: :?:
מטוס ו/או תוסף שמגיע עם מדריך ארוך ובאנגלית לא עולה אצלך על המחשב :?: כי הוא כבד, ארוך, ומעייף... :?: :?: :?:
אני יכול להמשיך בציניות אבל מניח שהבנת לאן אני חותר....
לא ממש מבין אותך :? יושב בן אדם שלא חייב לאף אחד שום דבר, משקיע מזמנו וכותב מדריך (שאם כבודו היה טורח לקרוא - היה מבין) מאיר עיניים, שימושי, ונכון לרגע זה גם ללא אופציות מקבילות.
והכל מונע מטוב לב, איכפתיות ובעיקר - נכונות לעזור לחברים לתחביב.
אני לא מכיר את אלכס - אין לי מושג מה שפת אימו ומדוע הוא בוחר לכתוב ולפרסם באנגלית - אני מניח שיש לו סיבה לכך, והוא אינו חייב הסברים על כך. נקודה :!:
באמת סליחה שאני מעיר לך - אני לא מרבה בכך - פשוט לא אוהב להיות "משטרת המוסר" של אף אחד - ואם אני חורג ממנהג זה - אני נוהג לעשות זאת בפרטי (יעידו על כך הבודדים שפניתי אליהם) .
אבל הפעם זה פשוט צורם לי - וגם אתה מפרסם את ביקורתך (כן - דבריך הם בהחלט הטחת ביקורת) באופן פתוח וגלוי כאן על דפי הפורום.
שוב סליחה אבל שמע - זה פשוט לא יפה :!: :!: :!:
Raz,
At the time I explained why unfortunately I cannot write in Hebrew: all my PCs have only the WinXP Pro US version due to compatibility concerns with the International version (which includes teh Hebrew version).
Anyway, the document that I prepared is written in English because a totally different reasons:
- people in our hobby and definitely those who fly real plans or surf teh Net should know English at a reasonable level.
- The document was written with the intention to help as many people (not only VATIL members) and I surely don't intend to translate it and every update that I plan to do, after spending my family time writing it in the first place
- The document is only 18 pages long (not 50 as you claim). I know, I counted each and every page twice - it is an 18-page document.
I recommend you read it instead of asking the same quesyions everybody asks (and get the same answers). Basically the purpose of the document is to have all the basic questions aswered before moving to more difficult issues.
Anyway I hope that you'll find teh time and energy to invest in learning - even if the stuff is not in Hebrew.
