liav ezra פורסם אוגוסט 8, 2014 דיווח פורסם אוגוסט 8, 2014 החברה פרסמה לפני כמה שעות כי העדכון הבא ל777 ייצא היום ! הנה ההודעה : :Service Pack B1 for the 777Hello Pilots!We are going to release the 777 SP1b update (Service Pack B-1) to you on Friday, 08AUG14. We anticipate the update becoming available for download during the afternoon, US EDT. SP1b update is primarily designed to improve stability on issues that we have been investigating and reporting to you as fixed. (Cockpit freezes, control freezes and some optimizations and other minor tweaks...) This update will come to you in the form of a universal installer that is capable of updating either the original release version of the 777, or an installed SP1 version of the 777.There is no need to uninstall the 777 in order to update to SP1b, and any guidance along those lines is just wasting your time- so 99.9% of you will be able to simply download the SP1b update, run the executable file, and you will have a perfect copy of SP1b installed the next time you run FSX. With this, SP1b update we are also going to refresh the 777-300ER to include some fixes that we have collected on that since it was released last month. I will have more information on those and the update process for the 300ER at release time... On the topic of "FSX pauses" and "airplane wanders at 8x and 16x" problems, this update is not expected to address those issues. We are still researching and collecting data on those two items and we anticipate eventually pushing out an SP1c to address those issues as we find/kill them. (I am prepping a major update dealing solely with those issues so that you have an idea where we are on that topic...) See you on Friday afternoon! תרגום קצר של ההודעה :שלום טייסים !אנו עומדים לשחרר את העדכון 777 SP1b (חבילת העדכונים B-1) אליכם ביום שישי השמיני לאוגוסט 14. אנו מתכננים כי העדכון ישוחרר בשעות אחר הצהריים בשעון מקומי (ארה"ב). Yuval Segev, Lior Paz, shachaf yasurr וגם 3 אחרים הגיבו לזה 6
liav ezra פורסם אוגוסט 8, 2014 מחבר דיווח פורסם אוגוסט 8, 2014 יכול להיות הם פרסמו כבר בפייסבוק אבל חשבתי לעדכן גם פה למי שפיספס David Ulman הגיבו לזה 1
Lior Paz פורסם אוגוסט 8, 2014 דיווח פורסם אוגוסט 8, 2014 קיבלתי מייל על זה אתה מפורסם אחי Ido Hen הגיבו לזה 1
David Ulman פורסם אוגוסט 9, 2014 דיווח פורסם אוגוסט 9, 2014 חברים הורדתי את ה sp1b קישור https://s3.amazonaws.com/PMDG_Downloads/file_library/servupd/PMDG_777_200LRF_6061_SP1b.ZIP
Joel Strikovsky פורסם אוגוסט 10, 2014 דיווח פורסם אוגוסט 10, 2014 זה כולל בתוכו את ה SP1 המקורי או שיש צורך להתקין את ה SP1b על גבי ה SP1 המקורי בלבד ולא ע"ג ה RTM? עדכון: מצאתי את התשובה לשאלה ב Readme This patch is universal and will update either your originally purchased 777 ora 777 that has been previously patched to SP1.
Stas Harchuk פורסם אוגוסט 11, 2014 דיווח פורסם אוגוסט 11, 2014 למי שלא שם לב, גם ה300ER עודכן. מי שקנה אותו יכול להוריד מאותו הקישור שהוא קיבל עם הקניה את הגרסה המעודכנות(לא צריך למחוק את הישן ניתן-להריץ התקנה על הקיים). מה העידכונים ל300ER(פרט למה שתוכן עבור הLR) אני לא בטוח, כנראה שרק כמה תיקונים ויזואלים למודל החיצוני.
liav ezra פורסם אוגוסט 11, 2014 מחבר דיווח פורסם אוגוסט 11, 2014 למי שלא שם לב, גם ה300ER עודכן. מי שקנה אותו יכול להוריד מאותו הקישור שהוא קיבל עם הקניה את הגרסה המעודכנות(לא צריך למחוק את הישן ניתן-להריץ התקנה על הקיים). מה העידכונים ל300ER(פרט למה שתוכן עבור הLR) אני לא בטוח, כנראה שרק כמה תיקונים ויזואלים למודל החיצוני. אני באמת שמתי לב שבOperatoin Center מופיע הודעה לעדכן אבל לא מצאתי קישור
David Ulman פורסם אוגוסט 11, 2014 דיווח פורסם אוגוסט 11, 2014 אני יודע חברים כנסו להתחל pmdg - operation center תוכלו לראות שנוסף עדכון ל 300 ותירצו אותו.
liav ezra פורסם אוגוסט 11, 2014 מחבר דיווח פורסם אוגוסט 11, 2014 אני יודע חברים כנסו להתחל pmdg - operation center תוכלו לראות שנוסף עדכון ל 300 ותירצו אותו. לי זה לא נותן להוריד את העדכון מהOperatioCenter כשאני לוחץ על עדכון ההודעה נעלמת Niv Tesler הגיבו לזה 1
David Ulman פורסם אוגוסט 11, 2014 דיווח פורסם אוגוסט 11, 2014 לי לא היתה שם בעיה בהתקנה , התקנתה את חבילת הצלילים של PMDG ?
liav ezra פורסם אוגוסט 14, 2014 מחבר דיווח פורסם אוגוסט 14, 2014 לי לא היתה שם בעיה בהתקנה , התקנתה את חבילת הצלילים של PMDG ? לא, בסוף החלטתי להוריד מהאתר עצמו וזהו.
