Aharon Dayan פורסם מרץ 2, 2018 דיווח פורסם מרץ 2, 2018 Shalom and greetings the EL AL virtual airline management, I flew today from LLBG to LLET. The ELY-ACARS refused to start. The error message said "Notify administrator of the switch error. Data not received and switch=verify". I tried to make manual PIREP filing but there is NO function on my dashboard for manual PIREP filing!! Please assist. Thanks, Aharon ELY0063
Daniel Hohashvili פורסם מרץ 3, 2018 דיווח פורסם מרץ 3, 2018 ,Hi Aharon Well, I'm not from the management, but I'm one of the crew members So, in order to achieve your wishes .(Enter ELY-ACARS then find the "Info" tab (it should be located at the top left sight corner "Enter "Settings" then you will see "URLBase" and "Browser URL copy the link given below to both tabs http://crew.elalvirtual.com ,Best regards Daniel
Aharon Dayan פורסם מרץ 3, 2018 מחבר דיווח פורסם מרץ 3, 2018 Thanks, Daniel Will try this trick!! Thanks!
Aharon Dayan פורסם מרץ 3, 2018 מחבר דיווח פורסם מרץ 3, 2018 Daniel, Should it be http://vcrew.elalvirtual.com, not http://crew.elalvirtual.com ?
Aharon Dayan פורסם מרץ 3, 2018 מחבר דיווח פורסם מרץ 3, 2018 Ok thanks, Daniel Daniel Hohashvili הגיבו לזה 1
Aharon Dayan פורסם מרץ 3, 2018 מחבר דיווח פורסם מרץ 3, 2018 Daniel, Your suggestion on the VATIL forums seems to work for logging into ELY-ASCARS but I have to see if it works after I finish my next flight and send my next PIREP. Smiling thanks for your kind help Regards, Aharon P.S. I do not know why my post is in weird blue blocks!!!
Alex Kmith פורסם יולי 11, 2019 דיווח פורסם יולי 11, 2019 On 3/2/2018 at 11:50 PM, Aharon Dayan said: Shalom and greetings the EL AL virtual airline management, I flew today from LLBG to LLET. The ELY-ACARS refused to start. The error message said "Notify administrator of the switch error. Data not received and switch=verify". I tried to make manual PIREP filing but there is NO function on my dashboard for manual PIREP filing!! Please assist. Thanks, Aharon ELY0063 Have the same problem again. They change URLBase? please help
