lalex
Tel Aviv VFR 1.2 to be released soon
You think you liked Ver. 1.0?
The new version adds 20 buildings more - The Textile Center (8), Isrotel, Tel Aviv Towers (2), Opera House, Amot Towers (3), America House, RG Twin Towers (2), NIP Tower, Toyota and MAYBE Dizengoff (2). In addition some Ver 1.0 buildings have been enhanced and textures optimized.
ETA? MAYBE this weekend, if not, then definitely the next one :lol:
After that, I'm getting back to Haifa VFR 1.1 which has been slowly getting improved. Now we need more buildings there - Rambam Hospital, Dan Carmel and Nof Hotels, IEC HQ, minor fixes (the cooling towers and RWY34 :) ).
Have fun,
Alex
אלכס,
ראשית תודה על כל העבודה הנהדרת שלך. האיכות מרשימה ומעצימה את חווית הטיסה שלנו. :D
ואם בחיפה עסקיננו, הייתי מציע להוסיף מלבד את בנין חברת חשמל גם את קומפלקס מת"מ ואת המלון (המכוער) שאני זוכר את שמו ושולט על מתאר קו החוף הדרומי.
המשך כך,
שי
4X-SHY
You're the greatest!
Do you still need pictures of anything specific in Tel-Aviv or Haifa?
10x guys,
Yes, the "ugly" Haifa hotel will make it too - it is an important VFR landmark. I think it is called Meridien but I am not sure.
Actually there are some pics I still need Ilan, etc:
1. TLV - I have done already America House but I need Asia House, Europe House - basically everything that goes on around the IBM HQ.
2. HFA - MATAM pictures and sizing (if you want it in), MATAM plans.
3. HFA - Ba'hai architectural details - sizing, angles, etc. What I really need is a top down and side projection of the entire complex. I have many pics but not good enough to do an accurate reproduction.
Basically, after these sceneries are finished I want to start working on Eilat. This would be a great time to send in pictures of everything that moves there - hotels, important buildings, LLET, etc. (anyone from Eilat?)
The general rule is that if you haven't seen it in my scenery and you think it is important, then send in the pictures, location (LAT/LON or description) and sizing info, and I will put it into one of the updates.
Pictures can be aerial but I prefer ground-based, in good light and not too "artistic" (crazy angles, etc.). The pics should cover all the sides, if they are diferent, and should highlight everyything special about the building. Small details are not important - remember - when you fly you do not see buildings from less that 100m! and even that is an exaggeration. The only exact details I need is for airports.
Pics can be sent to virtu_al@netvision.net.il - and never more that 2MB/day.
Regards,
Alex
after u will finish TA haifa and eilat
what the next city u will working on? (if u will...)
btw
your eilat scnery will work ok with the eilat airport (that includes part of the city)
(still on the no Hebrew computer, sorry for that guys)
ok, wilco.
I happen to be a lot around the (former) IBM complex (being a lawyer u know...), so I'll take the digi cam with me next time. I will also try and ask my ATC friends at Eilat to take some pictures.
Hof Hacarmel has a new transit station which should be in too. I would put Rambam and Eged too, since it's represents Bat Galim.
I'll be in touch, thanks!
Ilan
ok, wilco.
Ilan
1. Lawyer? Nice to know .
2. Roger on the digicam - thanks.
3. Egged Bus Station is already in HFA VFR (needs to be fixed a bit though). Rambam will be in.
4. Eilat - Double thanks
Best,
Alex
btw
I don't know. Maybe it will be about time to get back to flying online .
Alex
קודם כל תודה רבה! לפי התמונות זה נראה מצוין... חבל שעם הפנטיום 3 550 שלי כל תוספת קטנה מורידה לי תFPS לרמה שאי אפשר לנחות בה, אפילו הAUTOLAND מפספס בדרך כלל :P
רציתי לשאול אותך אם אני יכול לעזור לך עם הסינרי? הייתי ממש שמח לעזור ויש לי די הרבה ידע במידול ב3DSMAX (שלפי מה שהבנתי GMAX בנוי עליו) ופוטושופ בכלל...
אולי אני אוכל במקביל להכין ולמדל עוד מבנים...
אז אם זה באמת יכול לעזור לך ואתה מסכים, תגיד לי ונדבר :)
אני רואה רק את הסמל של נענע
תמונות מהממות!
איזה מטוס זה?
והאם יש לך עוד :?:
757-200 של ארקיע
כן יש עוד שמתי בגיימר הכל פעם אני אמצא את הלינק רק שניה
-עריכה-
הנה הכל רשום כאן... באמת שכחתי לשים תמונות בפורום הזה.. לא משנה כבר
http://www.gamer.co.il/gamer2/php/topic ... cid=287317
לכל המגיבים, וכן גם לאלכס...
לא שיש לי בעייה עם האנגלית... :roll:
אבל אודה לכם אם תוכלו לכתוב להבא בעברית...
יש כאלו שיש להם קשיים עם זה...
I see,
I don't have Hebrew on my computer since Hebrew screws up the directory and file names for certain applications that I need. Therefore there is no hope to have Hebrew anytime soon :-(.
Anyway, I understand that this is a problem, and I will reduce my presence here to only announcement posts.
Regards,
Alex
בשום פנים ואופן לא!
אין שום בעיה עם אנגלית בפורום אלכס, ואתה יכול להמשיך ולכתוב באנגלית.
השפה הרשמית בואטסים היא אנגלית - חובה לדעת אנגלית בסיסית כדי להיות חבר בואטסים.
הפורום הזה מוגדר כפורום כללי הפתוח גם לאורחים מחו"ל, ולכן הכתיבה באנגלית מותרת ולפעמים אפילו רצויה.
מי שיש לו בעיה עם אנגלית יכול להעזר במישהו אחר שיתרגם לו - בכל מקרה מדובר על מקסימום 3-4 חברים מתוך קרוב למאתיים חברים רשומים.
בקיצור - אלכס, תישאר! ;)
עבודה נהדרת אלכס
אבל איך שחכת את אחד מהסמלים הכי חשובים בעיר חיפה ותל אביב
מגרשי הכדורגל קרית אליעזר בחיפה ואיצטדיון רמת גן ובלומפילד בתל אביב זה יהיה ממש אדיר עם תוסיף את המגרשים האלה לסינרים שלך הם על בטוח יוסיפו נוף מאוד יפה ונחמד לחיפה ותל אביב:)
אגב עם אתה צריך תמונות ממגרשי הכדורגל אז צור איתי קשר ואני ישלח לך
I see,
Regards,
Alex
No way, man!
You're not going anywhere!
אתה יותר ממוזמן להישאר, ואם תביא עוד כמה מהמפתחים להיות חלק מהקהילה הזו גם הם, זה יהיה נפלא.
ברור לי שאתה קורא עברית, וכל אחד בעסק הזה חייב לדעת אנגלית ברמה סבירה!
אני רוצה לומר לכם שלפני זמן מה שאלתי בפורום של SAG (חטיבת שוויץ/גרמניה/אוסטריה) שאלה על סנרי. הפורום כולו דובר גרמנית, ואף אחד לא התייחס (אולי זה בגלל שהם אנטישמים? לא יודע).
בכל אופן, זו הרגשה מחורבנת לזר שבא להתעניין (אני יודע שאתה לא זר, אלכס) ואנחנו חייבים לכבד את כל מי שבא לכאן וכותב באנגלית - ישראלי או זר.
